Old 05-03-2015, 02:53 PM   #1
1700camaro
Liked 226 Times in 115 Posts
Default Radial Slicks Moving On Rim
I have 20 - 25 passes on our new Hoosier Radial Slicks (9x30) mounted on 8" wide Cragar Superlights. The slicks move about a 1/2" after about 5 passes. The Driver's side is the worse. I rotate them to try & re-index, but of course that's not going to work. The rim bead/tire bead were cleaned with acetone & mounted dry on the 1st 10 runs.
Next, I broke the beads clean them again. Then I glued them using 3M black weatherstrip adhesive. They are still moving on the rims. I don't know what to do & don't want bead lock rims.
The car weighs 3100 lbs. with driver. It has a pump gas 434 Chevy 630 hp/600 ft. lbs. torque. 5800 stall, 1.76 glide & 4.10 rear. Runs 10.0s - 10.40 depending on tune & track with mid-high 1.4 60's.
Would like to here some suggestions.
1700camaro is offline   Reply With Quote
Old 05-03-2015, 02:55 PM   #2
1700camaro
Default Re: Radial Slicks Moving On Rim
I forgot we are running 18-20 lbs. air pressure.
Old 05-03-2015, 06:05 PM   #3
Tex013
Liked 43 Times in 25 Posts
I clean the rim bead area then just use Permatex High Tack gasket sealant . Inflate to around 25-30 psi and let sit for a couple of days then good to go . Only ever had to redo this once . Bugger to clean the rim when replacing tyres , I use paint thinner
Good luck
Tex
Tex013 is offline   Reply With Quote
Old 05-03-2015, 07:20 PM   #4
HandOverFist
HandOverFist's Avatar
Liked 33 Times in 16 Posts
I had the same problem with the Camaro when running 17psi. Went to 20psi and has not moved since. It's a given I don't have the tq/hp your car does tho. Our rims are 10" btw.
Rich Taylor
I/SA - 321
Old 05-03-2015, 07:25 PM   #5
Dyno
Dyno's Avatar
Liked 693 Times in 205 Posts
put screws on them!
Old 05-03-2015, 09:16 PM   #6
Ed Wright
Ed Wright's Avatar
Should be on 10" wheels. When I ran 9" Hoosiers, on 10" wheels, I used 24 to 26 psi. You will use more air on wider wheels. Every radial I have used liked wheels 1" to 2" wider than the tread area. With the air needed for the wider wheels, it has always been faster, but with the added air my tires never slipped. No glue or screws on any of mine, just mounted clean and dry.
Ed Wright 4156 SS/JA
Old 05-03-2015, 09:47 PM   #7
Run to Rund
Liked 54 Times in 27 Posts
I sandblast the bead areas of the wheel.
Old 05-04-2015, 02:40 AM   #8
1700camaro
Thanks guys!
Sounds like I need wider rims & more pressure. I'm not putting screws in radials.
Old 05-04-2015, 02:20 PM   #9
j gardiner
Liked 55 Times in 29 Posts
We're their any adverse effects from the slicks moving on the rim.
j gardiner is offline   Reply With Quote
Old 05-04-2015, 02:26 PM   #10
Ed Wright
Ed Wright's Avatar
Originally Posted by 1700camaro View Post
Thanks guys!
Mine hooked harder, ran quicker on wider wheels anyway.
