Old 04-30-2015, 08:37 AM   #1
firebird
Default cast iron bowtie
i have been searching for a new set of phase 2 bowtie (14011034castings) heads--i haven't had any luck ---are they discontinued ?
firebird is offline   Reply With Quote
Old 04-30-2015, 01:36 PM   #2
carl hinkson
Liked 18 Times in 10 Posts
Default Re: cast iron bowtie
Probably are discontinued since GM is offering the Vortec Bowtie heads which are light years over the older Bowtie heads.
carl hinkson is offline   Reply With Quote
Old 04-30-2015, 09:03 PM   #3
race watcher
I have 1 head new. It is out of box but has never been touched. I would like to give it a new home.
race watcher is offline   Reply With Quote
Old 05-01-2015, 01:07 AM   #4
MAURICE BLENDHEIM
Liked 285 Times in 87 Posts
Firebird…Try Reher-Morrison's. They might have some "upstairs". Good Luck…MB.
MAURICE BLENDHEIM is offline   Reply With Quote
Old 05-07-2015, 10:09 AM   #5
firebird
What pistons can i run with the vortex heads----i have Mahle dome pistons with my rotating assembly. Is it wise to machine them to fit?
Old 05-07-2015, 10:59 AM   #6
Dragsinger
Liked 99 Times in 60 Posts
Firebird, an experienced machinist will have a fixture to measure the piston dome/top thickness. If you can machine to the needed dimension and have enough thickness remaining it will be fine to do so.
I "think" it has been said the Vortec is best with very small or no dome.
I do not know the min thickness needed but figger someone will help with that.
Larry Woodfin 471W
Old 05-07-2015, 03:43 PM   #7
firebird
thanks for the reply ---maybe i'm to old to take a shot at this class---would a different set of pistons be a better option ? i want good compression ratio--THANKS FOR THE HELP
Old 05-07-2015, 06:26 PM   #8
Dragsinger
Firebird, what are your plans? What class and buildup details?
Larry Woodfin 471W
Old 05-07-2015, 11:57 PM   #9
firebird
I'm still banging away at the ss/cs with a 350 chevy
Old 05-08-2015, 12:59 AM   #10
SSDiv6
Liked 1,603 Times in 583 Posts
You can use the large port Bowtie Vortec cylinder head or the approved Dart Cast Iron head.
