Old 03-22-2015, 10:35 AM   #1
dlv4540
Liked 2 Times in 1 Post
Default 1969 396-350HP JF Coded Engine
1969 396 350HP coded engine casting number 3935440 dated G-8-8 and stamped T0830JF 19N506393. Motor was pulled from the car in the mid 1970's and the motor has not been taken apart. 3931063 oval port heads dated H-1-8 & H-19-8, intake 3931067 dated G-29-8, distributor 1111498 dated 8H8, water pump pulley
330556 AS. The motor still has the lift assist brackets, chrome factory valve covers, fuel pump and line with fuel filter, dipstick and oil pan, timing cover and harmonic balancer. The Rochester Quadrojet carburetor is 7044502 BM dated 3063 and the water pump is 3969811 dated D-28-71 (both are not correct but functioned well and look the same as the original parts missing). Nice complete overall engine and would be great for a super stock or restoration $2500. Can ship if you cannot pick it up and can provide pictures with an email address. I can be reached at 330-770-2517 for any questions on the engine.
dlv4540 is offline   Reply With Quote
