Old 03-21-2015, 08:53 PM   #1
jerry99
Default advice on purchasing correct scan tool
I need advice on buying a scan tool that's capable of retarding cam in 99 5.7 vortec . I've been reading through these forums for days now hoping to find a trick that fixes my problem with out' replacing everything bolted to and around it . I'm getting the "random misfire" code along with o2 sensor . My motor is running horribly .It's missing ,knocking and has no power. I've done almost everything most the other guys have and still the same thing. I know the cam has to be retarded 2 degrees but I don't have the proper scan tool to do so. I don't want to just keep spending money that I don't have on parts that don't fix the problem. Any advice on purchasing a scan tool that is capable of doing this? One other question. I have right at 200 lbs of compression on all cylinders except number 3. It has 150 . Could this be the cause of the misfire or could the misfire be the cause of the low compression in that cylinder? Thanks for your help...
jerry99 is offline   Reply With Quote
