Old 03-03-2015, 10:29 PM   #1
Mark Faul
Liked 43 Times in 9 Posts
Default Cleaning up garage.
Cleaning the shop. Some new, some used. Prices don't include shipping.
Open to offers on all parts.
Used parts...
Turbo 400 chevy 9.5" tail shaft worked great when removed. Has a shift kit. $250
Turbo 400 BOP short tail shaft $100
Turbo 400 BOP 9.5" tail shaft. $100
2 TCI aluminum forward drums. Have slight wear. Can send pics $200 each
2 TCI aluminum direct drums. Slight wear. Can send pics also $200 each
3 steel billet splayed main caps for bowtie SBC #2,3,4 $50
Pair of coil springs 110# 14" long 2.75" ID 3.5" OD
Weiand electric water pump for SBC. Probably needs seal kit that's available. $50
Shogun "cool tool" that bolts to the converter to cool it off. $10
PermaCool electric fan 10" diameter. Was on a trans cooler. $20
15 Sherman (Schubeck) lifters, used, in great condition. $400
Areomltive A1000 pump rebuildable, $100 (was told $200 to rebuild)
Mr Gasket 2" open carb spacer #6007, used $15
Mallory fuel filter #3140 used $30
SBC chrome valve cover "Chevrolet" used $35
Following parts are new....
Moroso 63760 thermo switch for water pump or fan $25
Child's and Albert ring set
.031 dykes x 4.140 x .170 ductile dura moly
5/64 x 4.130 x .155 cast iron taper face
3/16 oil rings 4.135 $100 for the set
2 pairs Mr Gasket 5800 head gaskets 400 SBC $25/pr
Felpro BBC 1410 header gaskets $12
Felpro BBC 1211 intake gaskets $12
2 Felpro BBC 1037 head gaskets $45pr
King BBC CR849HP30 Rod Bearing Set $50
Thanks for looking!
Call or text 253-906-9643
Last edited by Mark Faul; 03-04-2015 at 10:17 AM. Reason: Remove an item that sold
Mark Faul is offline   Reply With Quote
