Old 02-23-2015, 10:01 AM   #1
Robbie Welch
Liked 262 Times in 124 Posts
Default RPM switchs
Who's RPM switch for shifting are you using. I had a problem with the 2-3 shift (shifting early) and I'm thinking about changing switch's. Also I put a 16v battery in the car a couple years ago the switch has worked great for a year or so, has anyone had a problem with the switch and 16v. Thanks Robbie
Old 03-10-2015, 08:32 AM   #2
Robbie Welch
Default Re: RPM switchs
I replaced my old RPM switch with a switch from Digital Delay and so far it's worked great. It has a few features on it I like, it has a momentary pause adjustment so when its shifts it stays activated for a set time and then looks for the second shift rpm. It also doesn't have to have a big rpm drop to shift again. So far so good.
