Old 02-12-2015, 09:14 AM   #1
mykids
Liked 2 Times in 1 Post
Default Mopar 8 1/4 rear + many weld wheels + lakewood
8 1/4" REAR BACKING PLATE TO BACKING PLATE - 54 3/4" - INSIDE PERCHto INSIDE PERCH 41" - OUTSIDE PERCH to OUTSIDE PERCH 46" - CENTER PIN to CENTER PIN 43" ---- 4:56 GEAR IN IT W/4:88 NEW IN THE BOX SOON TO BE INSTALLED IN THE REAR $1500 obro - SHIPPED TO ME FROM WEST COAST -
ALSO HAVE LAKEWOOD SHIELD AND BLOCK SAVER PLATE FOR 318-340-360 WITH CLUTCH FORK Z BAR BALL MOUNT $200 obro -
MOPAR PERFORMANCE PINION SNUBBER FOR 8 3/4 NEW NEVER USED $50 OBRO -
ALSO HAVE A LOT OF WELD WHEELS:
(4) 15X14 WELD PRO STARS 2-- W/3" BACK SPACE & 2--- W/6.5" BACK SPACE
(2) 15X12 WELD ALUMASTARS W/4" BACK SPACE THEY CURRENTLY HAVE (2) M/T 30x13.5x15 ET STREET DRAG TIRES (DOT STREET SLICK'S) BUT I WOULD SELL JUST WHEEL's
CALL 508-TWO SIX NINE-9611 or e-mail Thank's For Looking
mykids is offline   Reply With Quote
Old 08-13-2016, 11:12 AM   #2
Bob Buntin
Default Re: Mopar 8 1/4 rear + many weld wheels + lakewood
I saw your ad with the weld wheels. Do you still have the 15x14 with the 3" backspace? The bolt pattern was not listed. Is it a 4 1/2 or 4 3/4. Unfortunately I need a 4 3/4 on my Dart because at the time Strange only had a run of 4 3/4 axles available.
I can be reached at hustlinhemi @gmail.com
Thanks
Bob Buntin is offline   Reply With Quote
Old 08-13-2016, 03:25 PM   #3
Bob Buntin
Are the 15x14 Weld Wheels with the 3' back space still available? What is the bolt circle pattern? I need a 4 3/4 bolt circle.
Thanks,
Bob Buntin......hustlinhemi@gmail.com
Old 08-13-2016, 08:36 PM   #4
mykids
Bob sorry all the wheel's have been sold
