Old 02-05-2015, 06:05 PM   #1
John Nechiporchik
Liked 13 Times in 7 Posts
Default Optispark question
I am replacing the cap/rotor/isolator on my optispark with MSD parts (P/N 84811).
The car has a crank trigger and is not using the opti electronics.
Can I remove the electronic module and sensor wheel or just leave them in place?
Also, can I eliminate the metal heat shield or leave it in place?
Thanks,
John
John Nechiporchik is offline   Reply With Quote
Old 02-05-2015, 07:46 PM   #2
Rob Petrie E395
Liked 216 Times in 77 Posts
Default Re: Optispark question
I leave it all in there.
Old 02-05-2015, 09:16 PM   #3
Dickens
Liked 12 Times in 8 Posts
The rotor is mounted on the code wheel and a thin spacer. Although the spacer is small, I think it is best to leave them in place.
You may also want to consider tack welding the optispark drive shaft to the rotor mounting. The phase is typically off due to the pressed parts turning on the shaft.
DDD
Dickens is offline   Reply With Quote
