Old 02-03-2015, 03:57 AM   #1
Bernhard
Default Pure stock and cam lobe design?????
So the engine I would like to build for Pure stock has a valve spring pressure of 120 closed 300 open.
.475 lift and a rpm range 5500 to 6500
So is the cam profile designed around the valve spring because it is the limiting factor?
Are these questions for the cam company and engine builder/parts supplier?
Bernhard is offline   Reply With Quote
