Liked 557 Times in 217 Posts
Onan CMM 7KW RV generator. 7000 watts 120 volts 50 amp output
This is a 2007 machine. Gas carbureted unit, air cooled V twin engine Commercial Mobile units have some better components and features over std RV units. This one has 1790 hrs on it and is in very good working order with some new parts and is fully serviced and has been load bank tested. They routinely go to 5000hrs+ with proper care and maintenance. This unit will fit in a std generator compartment in a trailer or a larger gas powered motorhome. Add a battery and a fuel tank and a remote start panel in your trailer and you have all the power you could need. I can easily reconfigure it for 120/240 volt output if needed. Asking price is $1800. 973-328-6880 Ask for Rich......
Rich Biebel S/C 1479 Stock 147R Last edited by Rich Biebel; 01-30-2015 at 10:37 AM. Reason: Added some info |
