I have a brand new Motec EDL2 Advanced Data Logger I wont be using. Its one of the most advanced dataloggers available & is also a fully programmable controller as well. The Motec EDL2 is far superior to all Racepak dataloggers including the V300 & V500 in both hardware and software that makes it much easier to analyze & implement. Not to mention Motec also has the best support in the motorsport industry which is essential!! Cost $6600 from John Reed and its still new in box sealed. No longer building the car and figured someone else could use it. Ill sell for $3200obo
Pics https://www.dropbox.com/s/yqwz2kd3bp...%20AM.jpg?dl=0 https://www.dropbox.com/s/z5vbghzb06...81%29.jpg?dl=0 https://www.dropbox.com/s/6wk78u6gik...%20AM.jpg?dl=0 https://www.dropbox.com/s/zo3fjb3dy4...%20AM.jpg?dl=0 https://www.dropbox.com/s/1mw4cchab6...%20AM.jpg?dl=0 Racepak Picture of all the Racepak together https://www.dropbox.com/s/y2z7uijp3e...%20PM.jpg?dl=0 New Racepak Vnet Steering Position Sensor & Module 220-VP-SK-1 -$250 https://www.dropbox.com/s/op1vg56oys...%20PM.jpg?dl=0 https://www.dropbox.com/s/00xvx9ewwn...%20PM.jpg?dl=0 New Racepak Vnet String Potentiometer TPS Throttle Position Sensor Module # 230-VM-TPS $100 & Vnet String Potentiometer TPS sensor RPK-800-LN-STRINGP - $250 https://www.dropbox.com/s/htad0chesf...%20PM.jpg?dl=0 https://www.dropbox.com/s/hmcl2dbp23...%20PM.jpg?dl=0 New Racepak Vnet Extensions & Vnet to Can extensions. - $20 each https://www.dropbox.com/s/i32q8vvlu0...%20PM.jpg?dl=0 New Racepak Accel DFI Interface Module- 230-VM-EFIDFI- Allows Racepak IQ3 dash and other Racepak products V-net system to tap into Accel DFI sensor readouts. Brand new in package. Cost $375 Asking $300 https://www.dropbox.com/s/5unhzqv1ce...%20PM.jpg?dl=0 https://www.dropbox.com/s/pz40q7sxjw...%20PM.jpg?dl=0 Racepak/Haltech AFR AF1 Wideband 02 Oxygen Sensor/Controller that is lightly used & works perfect. The Racepak AF-1 is a single channel air/fuel sensor package engineered for the harsh conditions of the racing environment. The Racepak AF-1 is suitable for use with gasoline or alcohol, with calibration values available for either fuel types. Compatible with 12 volt or 16 volt high performance batteries & also features a programmable 0-5 Volt analog output, the Racepak AF-1 provides accurate, high quality air/fuel ratio data, essential when tuning for optimum engine performance. Only used for tuning a V8 motor on the dyno. Use with any Racepak Vnet, Racepak datalogger, Racepak dash or with Haltech or other device that can read CAN(with provided CAN to Vnet cable) . Perfect to use Haltech's Autotune feature. Comes with Racepak heat/water resistant Wideband O2 controller, (1) lightly used Racepak Wideband O2 sensor & wiring harness. Cost $360 - Price $300. Also have a spare new Racepak wideband O2 sensor that I can include for an extra $50 to buyer. Not needed, but nice to have spare just in case. https://www.dropbox.com/s/4kdw47dxy8...%20PM.jpg?dl=0 https://www.dropbox.com/s/ag2gm76aa7...%20PM.jpg?dl=0 New Racepak IQ3 clear protective cover Cost $75 - Price $60 https://www.dropbox.com/s/n1h1sa7tbh...%20PM.jpg?dl=0 New Racepak IQ3 black molded dash mount panel. Cost $100 - Price $75 or buy both IQ3 cover and dash panel for $125. https://www.dropbox.com/s/ud3aegzfby...%20PM.jpg?dl=0 New Racepak Smartwire Switch Panel - Machined from billet aluminum and anodized black, the Racepak Smartwire SwitchPanel was designed to reduce installation weight and clutter. Along with the Racepak Smartwire the Switch Panel functions essentially as a “command center†for all of your vehicle wiring & with the included V-net cable it integrates seamlessly with Racepak's/Haltech data loggers & displays as well as other data loggers & displays if using the appropriate Vnet interface cable. Switch Panel allows manual activation of 8 (circuits) through the 7 toggle switches and 1 starter button. Cost $300 - Price $250 https://www.dropbox.com/s/obodr18xup...%20PM.jpg?dl=0 https://www.dropbox.com/s/fjwdzpxy6z...%20PM.jpg?dl=0 New Racepak Smartwire Switch Module - Machined from billet aluminum and anodized black, the Racepak Smartwire SwitchModule provides the ability to utilize an existing switch panel in conjunction with a SmartWire module. Existing switches are connected to the spade connectors of the SwitchModule, with switch data routed to the SmartWire via a single cable. Adding a second SwitchModule is quick and easy, through the use of a short jumper cable between the two modules. Cost $300 - Price $250 https://www.dropbox.com/s/n3accowc0h...%20PM.jpg?dl=0 (2)New 36" Smartwire to Switch Panel Serial cables- Cost $54 Asking $40 each https://www.dropbox.com/s/49da896bev...%20PM.jpg?dl=0 (2) New 36" Smartwire to Vnet Cables- Cost $54 Asking $40 each https://www.dropbox.com/s/49da896bev...%20PM.jpg?dl=0 |
