Old 12-22-2014, 08:22 PM   #1
wldtm
Default 6.1 hemi drag pack engine parts
6.1 Hemi block, align honed, honed with deck plate. ARP main and head studs included. Block has been prepped to have oilers removed. 4.055 bore $2500
6.1 Hemi drag pack pistons (never ran) w/ total seal rings gapped to the above block 425$
5.7/6.1 hemi Manley Drag Pack Rods -new never ran-1200$
6.1 crank-turned down by ohio crankshaft to 2.100 rods (not balanced yet)- $300
Hemi timing kit – new never ran?
ATI balancer- blemish sold newfrom ATI- 275$
Hemi oil pump- new never ran- 150$
Take out Hemi drag pack cam USED – $200
6.1 Lifters new from Mopar 300$
6.1 Hemi heads ported new- need to have one intake port welded. Never ran! These are ported and I can get flow sheets. $900.
Used Gen 3 Milodon oil pan- $200
New AEI Hemi Engine plate and truck timing cover (needs to be machined)-$275
New AEI Stainless steel gen 3 hemi header flanges- Not sure on port configuration- 250$
6.1 fuel rails- $50
6.1 Hemi coil packs –
Please understand I work long hours and have two young kids that I spend my spare time with, which is why I am selling my parts. It will take a few days to get items shipped out. Block and heads must sell first.
If it is marked as new, than it is new. If it is NOT marked as new than it used. I would appreciate you asking about condition if you are unsure.
This is approximately $7,000 in parts. I will sell as package deal for $6,000.
I have almost everything to build a clone 6.1 drag pack engine. I do not have injectors, EFI system, head gaskets, valves or springs, or rocker gear. The rotating assembly does need to be balanced.
Block and heads must sell first before I sell the other items.
wldtm@hotmail.com
Thanks for the ad!
wldtm is offline   Reply With Quote
