Old 12-21-2014, 10:41 PM   #1
Dragsinger
Liked 99 Times in 60 Posts
Default need steering wheel help with the Super 10
I need help with the steering shaft to wheel adapter. I plan to use the factory column [of course, less horn and air bag]
The parts I see listed are confusing, photos not clear or not enough detail.
The factory wheel has about a 6" dish but need to install an aftermarket steering wheel with about 3" dish. Also, about 14" OD.
This is for my 1997 S-10 super stocker buildup. I do not need a quick dis-connect hub but that is an OK option.
Some of you racing later models what did you do about the steering wheel while retaining the factory column?
Larry Woodfin 471W
