Liked 240 Times in 112 Posts
I guess I'll start this by saying that my health is a limiting issue on doing heavy work on my car. That said, given one of each transmission comparibly prepared with similar convertors, EXCEPT, the C6 has a 2.75 gearset in it & my car is still a little light for "N". (the car 72 Cougar 351C 2BBL that has yet to touch its index) Opinion's ?
Dave Noll, EF/S ,?/SA 6526 |
Without a doubt, the C4 is the better choice. Lighter, faster, cheaper, more room for headers. With a 2.91 low gear set, that 2V Cleveland will be very happy.
How well do those 2.92 gear sets hold up ? I killed one of the stock 3 gear planets in my last C4. My headers will clear a C6, now..
Liked 56 Times in 21 Posts
get a pro trans gear set for the c-4
Vic Guilmino 1129 STK |
Liked 805 Times in 245 Posts
AS few years back, we swapped from a C6 to a C4 in a 2900# bracket car, small block, both trans were 8" converter, no trans brake. It went .25 quicker. Wasn't a perfect back to back test but pretty close. I have no question that there would be significant improvement switching to the C4. Lots of good parts for C4's these days, no reason for strength issues to be a problem.
C4 it is,Thanks Guys. Guess I better get to selling some stuff to get one of those gearsets.
Dave Noll, EF/S ,?/SA 6526 Last edited by Dave Noll; 12-12-2014 at 03:33 AM. |
Liked 160 Times in 51 Posts
I run a Broader 2.92 set and also have a ATI 2.92 set C-4. The Broader set looks more robust than my ATI set and held up for about 3 years of hard abuse before it looked like it needed rebuilding. The actual planetary is from a 125C GM, so I just rebuilt it using those parts every few years. But last I heard that set may or may not be available, check Broader Performance website. Good guys.
Where the Broader stuff uses Ford hubs and GM gear sets the ATI uses GM hubs with Ford splines pressed and welded in and just gives you GM clutches to make it work in a C-4. I haven't used my ATI set yet but, it looks like it will hold up ok. Wasn't as impressed with what I got vs the Broader set up. With all of the C-4's the front planetary is the weak point usually with thrust washer wear on the side of the planet pinions. There are limited manufacturers of the 2.92 sets for C-4 and I haven't seen a 6 pinions 2.92 set yet. If you can find ones with Torrington bearings on the planet pinions even better. Maybe some others can chime in.
Brian Thompson NHRA Stock / Super Stock Class P/SA 6665 SS/MA 6665 Last edited by fordteacherguy; 12-13-2014 at 09:17 PM. Reason: Spelling |
Well since it came up, I'm real curious how you rebuild those. I just checked Broader, they still show one. What about the ACT Automatics unit ? All I see on ATI is for the 6 pinion stock ratio & the low drag piece.
EDIT: Okay i can how to rebuild the stock piece if I had a Bridgeport still available to me, BUT ........ Is that GM piece the same way ?
Dave Noll, EF/S ,?/SA 6526 Last edited by Dave Noll; 12-14-2014 at 04:19 AM. |
#10 | |
Liked 172 Times in 81 Posts
Jim Mantle V/SA 6632 |
