Old 11-12-2014, 07:51 PM   #1
sully3358
Liked 10 Times in 7 Posts
Default 584 sr20
Dart Big M 9.8" block w/ .904 bronze lifter bores
Callies Magnum crank
Manley rods
Custom Wiseco pistons
Total Seal rings w/ steel top ring
Moroso oil pan
Moroso billet oil pump
ATI balancer
Cometic gaskets
Crower .903 "needle-less" Enduramax lifters
7/16" pushrods
Comp Cams 873/823 286/305 7/4 swap camshaft
T&D shaft rockers
Brodix SR20 CNC cylinder heads w/ titanium intake valves
and $1,250 additional hand port work
Edelbrock SV565 intake manifold port matched
Sheet metal valve covers
Built in March 2014 by Steve Schmidt. Less than 80 passes on it.
Intake to pan $17,500
Can be purchased with 1250 APD max speed carb, star vac pump, csr water pump, msd crank trigger ignition, starter, etc per your needs.
Chris Sullivan
217-899-2143
sully3358 is offline   Reply With Quote
