Old 11-10-2014, 04:30 PM   #1
Mike Gardner
Default Parts Sale - Retiring - New (final) List
call Mike G 703 675 4479
valve cover wing nuts $5.00
rod ends $5.00
Aeromotive fuel filter cannister only inline $20.00 SOLD
Percys EGT sensor $25.00
NOS pressure gauge $20.00
Raytek Laser temp. sensor for starting line $50.00
Misc bags of bolts for spares in trailer $30.00
Misc spark plugs $50.00
Kirkey HD Alum sprint car seat we had in Super Stocker $250.00
305 CI Stocker engine & 416 heads less valve train, rods, pistons, $700.00
305 block stock $50.00
454 black cracked cylinder stock $75.00
aluminum trailer step (not a fold up, sits on ground) $40.00
632CI rods and pistons, many boxes, all good from freshen ups $800.00
8 10 Lb Blue NOS Bottles filled to 24 lbs $1,600.00
2 10 lb NOS bottles empty $100.00
Assorted new BB gasket sets $150.00
1 box used braided line large assortment $200.00
1 box uesd AN fittings large assortment $100.00
New in box Moroso cool can for stocker or s/s $50.00
3 Ring & Pinions $150.00
2 Moroso 2qt oil filters $20.00
9 cams BB & SB $450.00
3 Converters 2 BB Nitrous & 1 Stocker SB $400.00 each
1 set used BB roller lifters $50.00
1 set used SB springs $25.00
1 set used stocker rockers SB $20.00
Autometer elec oil pressure gauge $20.00
VDO volt meter gauge $10.00 SOLD
8 Flexplates $30.00 each
new MSD Grid wiring only (no grid) in box $30.00
Assorted Powerglide parts/pump/valvebody/shafts/etc. $200.00
1 set BB Used Crane roller rockers Gold $70.00
2 sets BB valve springs $100.00
Biondo Air inline throttle stop single air line w/ bleeder $40.00
Air solenoid for t/stop $10.00
9" rear shims $5.00
Spare MSD caps & rotors used $20.00
Moroso Ultra spark plug wire set $50.00
Large box assorted push rods $50.00
I steel drive shaft OLD! $25.00
Assorted brackets & such $10.00
3 sets used BB valve covers $100.00
K&N air cleaner only $50.00
2 mini alternator brackets $30.00
Stefs Vacuum pump old style $50.00
Dragster short drive shaft steel $40.00
Steering Wheel Aqua $10.00
1 right side BB header coated $50.00
All Above Parts call Mike G 703 675 4479
Moser 12 Bolt rear for 4th generation Camaro, 456 gear, spool, 33 spline axles, torque arm bracket $1850.00 Call Fuzzy 540 454 2001
4th Gen Camaro Mild Steel 8 point roll bar kit new in box. $150.00 Call Fuzzy 540 454 2001
1995 Camaro body, interior removed for rebuild as stocker. $500.00 Call Fuzzy 540 454 2001
Mike Gardner is offline   Reply With Quote
