Old 10-08-2014, 09:44 AM   #1
Shawn Pinkerton
Default Aluminum 598 SR20 motor
Motor is currently in the car. You can come watch run at the track or see run in the shop.
598 SR20 Motor
Aluminum 9.8 Brodix block
Moroso Pan
Moroso Billet Pump
Callies Crank
Weisco Pistons
Total Seal rings
Eagle rods w/ L19 bolts
ATI Balancer
Jesel Belt Drive
Bullet Cam Shaft
Crower 903 hippo lifters
Manton 7/16 push rods
Cometic Gaskets
SR20 heads with *** intake vavles
T&D 1.80 rockers
Brodix inteak
Chrome Valve covers
APD 1250 Gas carb
Abruzzi 9 inch converter.
Does not include accessory items such as starter, fuel pump, water pump and vacuum pump.
Motor has half a season on it. Car ran 4.50's and 7.10's on motor. Have sprayed a small shot 0.60 out for 2.50 seconds to go 6.90's.
Asking $26,500
Call Dion 330-584-3679
Shawn Pinkerton is offline   Reply With Quote
