Old 09-23-2014, 10:07 PM   #1
Shifted302
Default 57 283 chevy
I have a all standard 283 block casting 3731548, heads casting 3731554. Took engine apart some years ago and had everything hot tanked everything has some surface rust. Mostly everything is here but the intake and I had the pistons pressed off the rods, exhaust manifolds, dist, oil filter canister, front motor mount brackets, oil pan, draft tube etc. Is here. Make offer. If you want it shipped you arrange that. Im in kingman az
Shifted302 is offline   Reply With Quote
