Old 09-19-2014, 07:46 PM   #1
west coast
Liked 230 Times in 75 Posts
Default 87-93 stocker Mustang SBF parts
C&L air meter 76mm with 24lbs injector tube and a air meter $75
MSD Pro Billet dist part# 8456 for 5.0 liter mustang 20 minutes of dyno time. $170
MSD Ignition 8227 - MSD Blaster TFI Coils $20
94-95 ford extender ford Mustang 5.0 liter. You can adjust your factory rev limiter and your air/fuel ratio $150
Comp valve springs 942-16 New still in sealed box $30
Comp rockers 1235-16 stock style rockers 1.6 ratio $100
NEW C4 Small Block Ford Chromoly SFI Flexplate 157 Tooth 28 oz SBF External $30
"COMP Cams 1052-16 - Comp Cams Aluminum Roller Rocker Arms Details
Ford 302-351W 1977-92 Pedestal Mount
High Quality Extruded Aluminum
Fully Rollerized At Tip
Fully Rollerized Trunion
Adjustable Pushrod Seats
Bolt On Simplicity
These were only slightly used some dyno time and one night at the drags. $300
I can text pictures if interested.
Price plus the ride.
James Boyce 6052 K/SA Stock
National record holder 2015,2018,2 times in 2022,2023
west coast is offline   Reply With Quote
Old 09-19-2014, 10:31 PM   #2
Slickfoot
Liked 2 Times in 2 Posts
Default Re: 87-93 stocker Mustang SBF parts
Jim you have a PM
Slickfoot is offline   Reply With Quote
