08-30-2014, 06:50 PM | #1 |
Liked 12 Times in 6 Posts
Hurst Quarter stick
Will a Hurst Quarter stick for a Turbo 350/400 reverse pattern work on a metric 200 trans?
08-30-2014, 07:55 PM | #2 |
Liked 28 Times in 9 Posts
Re: Hurst Quarter stick
If you have the automatic one / two shift it will work great ; it becomes a forward rather than reverse pattern however .
08-30-2014, 10:01 PM | #3 |
Liked 230 Times in 108 Posts
Turbo Action Cheetah shifter works great with a THM 200 ! That is what was in that car when it had a console.
08-31-2014, 08:42 AM | #4 |
John,
I used the same Turbo Action shifter in my 87 Firebird with a Th200 and Th350. No changes needed, other than initial setup. Know the shifters are a little different, but patterns were the same distance. I would try it and see. Good Luck. Ken Stock 412 |
09-01-2014, 11:36 AM | #5 |
Liked 160 Times in 45 Posts
I did it, just had to use a different cable bracket at the trans.
09-01-2014, 11:53 AM | #6 |
Thanks.
