Old 07-31-2014, 09:08 AM   #1
dlv4540
Liked 2 Times in 1 Post
Default 1969 396-375HP Motor
1969 396 4 bolt motor casting number 3955272 dated K-30-8 stamped T1217JD and 19K374421 down by the oil filter. The block is standard bore with the original 11 to 1 pistons, 3/8 dimple rods, 6223 steel crankshaft, freshly rebuilt 3919840 square port heads both dated L-4-8 and the 3933163 aluminum intake all cleaned up dated 12-14-68 along with the oil pan. Motor turns over freely and the top half is off for inspection.
I can ship this motor if you cannot pick it up $4750. I can be reached at 330-770-2517 for any questions or pictures needed. This is an original Chevelle 4 speed 396-375HP motor but could also be used in a Camaro or Nova just has a different code on it.
dlv4540 is offline   Reply With Quote
