Old 07-30-2014, 04:29 PM   #1
cojo
Default N/A Big Block Ford/605/1200+hp
Up for sale is my Big Block Ford C headed race engine. Makes a ton of power with all the documentation of the build including pics, dyno sheets, parts lists and other paperwork. Engine makes well over 1200 HP naturally aspirated and 1000 TQ in its current set up. Below are a list of hard parts that come with the engine:
Eliminator Ultra 4-bolt block
FMS C-460 heads (tons of port and polish work)
Ferrea valves
PSI springs
FMS ported cast intake
Super Light Weight Scat billet Crank
Grp pro mod rods
Diamond Custom Gas Ported Pistons/Coated
Low tension rings/total seal
FMS (60mm) roller cam bearings
Custom comp cam
T&D shaft rockers
Crower lifters
Manton ½” push rods
Pro systems SV1 1600 carb
Peterson dry sump oil/vac systems (4 stage)
Custom sheet metal pan and valve covers
MSD crank trigger
Meziere water pump
ATI damper
SFI flex plate
meziere $600 starter (billet)
front plate and midplate (adapted to run chevy pattern transmission)
Much more……
This engine is built for durability and has no issues! Comes from carb to pan turnkey ready for racing. There is a ton of money in this build! Wanting to go small block so will consider high HP N/A small block for trade.
$16500
can add a pro torque bolt together converter for this engine $1100 (paid $3100)
have engine create set up so it can be boxed up and ready to be shipped.
joe 281-802.428 3
cojo is offline   Reply With Quote
