Old 07-27-2014, 09:13 AM   #1
Dragsinger
Liked 99 Times in 60 Posts
Default S-10 Chevy in SS GT weight math
Racers,
please help me with the race weight of this combination
*2000 Chevy S-10 in SS GT
*327/300 @ 293 horse power factor[runs the 585 CFM Holley]
and
*327/275 @ 299 horse power factor[runs with a Q-jet]
I "think" it will run in truck class "B" which is 10.5 pounds per factored horse power less (250 pounds allowed for automatic trans] plus 170 for driver
So, is this correct, using the 293 factor as an example
293 x 10.5 = 3077 less -250 class allowance = 2827 + 170 driver = 2997 race ready with driver. I am correct?
Larry Woodfin 471W
Old 07-27-2014, 09:23 AM   #2
Hans Olsson
Hans Olsson's Avatar
Default Re: S-10 Chevy in SS GT weight math
Shipping weight of the truck?
Hans Olsson is offline   Reply With Quote
Old 07-27-2014, 11:20 AM   #3
Herbie Null
Herbie Null's Avatar
Liked 439 Times in 69 Posts
Originally Posted by Dragsinger View Post
Racers,
and
The 250 lbs is only used for adding or substracting on the shipping weight so you can move up or down in a class. Looking at your shipping weight and using the 250 lb rule, your truck fits A or B . At B race weight if your motor is rated at 293 HP you would multiply 293 hp x the weight break of 10.5 plus add 170 lbs for driver. In B you would have to weigh 3,246.5 rounded to 3,240 is least you can be at the scales.
Herbie Null 201 SS
Herbie Null is offline   Reply With Quote
Old 07-27-2014, 01:21 PM   #4
Dragsinger
Herbie, as I read the rule [and we need to double check this] the SS GT race trucks are in deed allowed to run 250 pounds light.
The rule book says, "trucks running with automatic transmission are allow 250 pound weight removal, that is to say, truck can run 250 pounds light for it's class"
Can someone verify I am interpreting this statement correctly?
Larry Woodfin 471W
Old 07-27-2014, 01:25 PM   #5
LE WILSON
I believe for GT truck you get a 250lb or 5% weight break which ever is less for an automatic. Factored hp x weight break minus 5% plus 170lbs for driver. 293x10.5=3076.5-153=2923.5+170=3093.5 rounding down to a min weight of 3090lbs.
LE WILSON is offline   Reply With Quote
Old 07-27-2014, 01:30 PM   #6
Dragsinger
Hans,
a 2000 Chevy S-10 with base 4 cylinder shows 2930 pounds on the NHRA guide. Please help with this, I do have conflicting feedback about the as raced weight for the SS GT truck classes.
Also, please check the SS GT rule book in ref to a 250 pound weight removal allowed for trucks with automatic trans. To me, the rule reads, "trucks with auto trans are allow to run 250 lighter than class weight"
Larry Woodfin 471W
Old 07-27-2014, 01:34 PM   #7
Kevin Love
Liked 19 Times in 10 Posts
GT trucks with automatics get both - 250 lbs to adjust up or down plus can run up to
250 lbs (OR 5% whichever is less ) light for having an automatic.
Kevin Love 5666 STK/SS
Kevin Love is offline   Reply With Quote
Old 07-27-2014, 02:06 PM   #8
Herbie Null
After reading the rule book, I would say this is dead on the dial. Sorry did not realize about the break for running an automatic, but it makes since now. 3090 lbs
Herbie Null 201 SS
Old 07-27-2014, 02:11 PM   #9
Hans Olsson
Shipping weight must be with the heaviest engine and trans for that year and model.
Old 07-27-2014, 02:12 PM   #10
Dragsinger
Le, Thanks, your math seems correct to me. I over looked the 5% and that is important because it makes about 100 pounds difference. [heavier] than my math.
I "think" it will require some ballast to put the S-10 at 3100 race pounds but with the truck chassis the weight placement most likely will be a traction advantage.
Besides, we have a "heavy" driver
Larry Woodfin 471W
