Old 07-17-2014, 08:05 PM   #1
mike2014
Default 1971 Dodge 413 Big Block
1971 Dodge 413 Big Block and matching 727 transmission. All original. $850.00
mike2014 is offline   Reply With Quote
Old 07-20-2014, 12:16 PM   #2
Harry 6674
Default Re: 1971 Dodge 413 Big Block
You better check the numbers again. They quit making the 413 in 1965. Thanks.
Harry 6674 is offline   Reply With Quote
Old 07-21-2014, 01:05 AM   #3
Phillip marvetz
Phillip marvetz's Avatar
Probably a motorhome power plant.
2009 V/SA Record Holder
Old 07-21-2014, 01:19 AM   #4
GTX JOHN
I believe they made a 413 engine well into the 1970s. It was in motor homes,
stationary engines, Oil well equipment and some HD trucks.
Very little interchanges with the car engines except block.
It has much higher cylinder heads with a wider intake by about an inch or more.
The exhaust manifolds look similar to a 340 but larger. Bigger water pump and different location for it. Several other distinctions are easily observable.
It does have a windage tray that you can use on regular B engines. I have scrapped all mine years ago.
John Irving
741 Stock
741 Super Stock
Old 07-21-2014, 08:46 AM   #5
STK1217
STK1217's Avatar
Liked 10 Times in 7 Posts
I had a 1972 Whinnie Motor Home that had a 413 engine from the factory.
STK1217 is offline   Reply With Quote
Old 07-21-2014, 11:02 AM   #6
Neil Smedley
Liked 22 Times in 7 Posts
I think the 413 block was used up through 1972 in motorhomes, especially Winnebago
Neil Smedley is offline   Reply With Quote
Old 07-21-2014, 11:53 AM   #7
Myron Piatek
Liked 138 Times in 51 Posts
Post Re: 1971 Dodge 413 Big Block
Harry,
They were used in med.- heavy trucks thru 1979 according to this and I believe in motorhomes as well. But I'm not familiar with the similarities or interchangability with other Mopar RB engines.
Similar info on Allpar.com.
http://en.wikipedia.org/wiki/Chrysler_B_engine#413
LOCOMOTION Racing
Old 07-21-2014, 02:49 PM   #8
Paul Precht
Paul Precht's Avatar
Liked 327 Times in 121 Posts
Originally Posted by GTX JOHN View Post
I believe they made a 413 engine well into the 1970s. it was in motor homes
It has much higher cylinders with a wider intake by about an inch or more.
Hi John, the heads and mani are different sometimes but the block has the same deck with thicker cylinders, all other parts interchange with any raised block, they are commonly used in Max Wedge stockers. The 361s were used for industrial use also but are less common.
Old 07-21-2014, 10:25 PM   #9
mike2014
Yes, it came out of a 1971 Dodge Winnebago motor home
Old 07-22-2014, 04:25 AM   #10
GTX JOHN
Sorry Paul.....I meant cylinder heads higher - Not block.
Half asleep when I posted the Reply and did not proofread text.
No racers out here willing to haul the 413 blocks away for free out here...
let alone whole engine.
John Irving
741 Stock
741 Super Stock
