Old 06-16-2014, 01:40 PM   #1
Eric Merryfield
Eric Merryfield's Avatar
Liked 502 Times in 130 Posts
Question Two Step Brake Pressure switch gurus chime in
How much less pressure on the switch is optimal versus staging pressure?
IE Stage @ 1100 switch set to engage at 900.......I think I learned the very hard way that if the spread is too high you get residual pressure and launch at two step RPM......My bad didn't check it when I raised the launch RPM.
Thanks
Eric
Eric Merryfield 1883 STK
