Liked 101 Times in 27 Posts
Proform 66666 2 piece timing cover ......anyone care to critique this item if they have had experience using it ???
NHRA AND IHRA STOCK ELIMINATOR 2772 |
Liked 4 Times in 3 Posts
I have LOTS of experience with these they do sorta work if you want to remove while in the car you probably need to remove the balancer. I replaced the special bolts with hex heads and thinned the heads down on a lathe. The middle gasket will try to squirt out on you because of the chrome plating they are also difficult to get to stop oil leaks. It still works better than dropping the pan to change cam timing.But not nearly as well as the Cloyes Hex-Adjust and the Cloyes cover I am now using !
Liked 1,436 Times in 299 Posts
I spent the extra $$$ on the Comp cams three piece cover and I don't regret it one bit! I remember using the proform thinking it would make cam changes on the dyno easy, and it was a real pain in the oil!
James Schaechter 3163 STK |
I use the Comp Cams cover. It has counter sunk socket head cap screws, which can be difficult to break loose, and you have to use silicone RTV to seal it. However, it works very well, it does not leak, and I can adjust my intake centerline without even removing my harmonic dampner.
I prefer the Cloyes fast adjust timing set, it uses bolts around the perimeter of the cam gear, and has a key that rotates the two halves of the gear easily.
Alan Roehrich 212A G/S |
Liked 799 Times in 236 Posts
I used this one, with some modifications. The front pan seal 'lip' is cast into it.
http://kmjperformance.com/small-bloc...ion-plate.html I removed the lip from the alum cover and used the 'lip' plate from this: http://kmjperformance.com/sbc-chevy-...all-block.html The holes in the alum. cover are pretty large. I made some spacers that locate into the recesses in the cover, used studs and 12 point nuts: ![]() Worked out okay. Still have to remove the balancer to get the cam access plate off, though: ![]()
"That'll never work....." |
Liked 507 Times in 116 Posts
x2
68 Chevy11 327 F/S |
