Old 06-13-2014, 10:08 AM   #1
Joe Grippo
Liked 41 Times in 4 Posts
Default Water Coolant Additives
I did a search but did not get definitive results. So what is the preferred water coolant additive for an aluminum radiator, electric water pump and iron heads and block. Looking for some rust inhibitor qualities along with some pump lubrication and increased cooling efficiency. I have seen stuff from Driven, Royal Purple, Redline and others, are there any differences or is one better than the others?
Also, any thoughts on the age old debate of distilled water verses regular tap water?
Joe Grippo is offline   Reply With Quote
Old 06-13-2014, 04:02 PM   #2
1720
1720's Avatar
Liked 2 Times in 1 Post
Default Re: Water Coolant Additives
Our engine guru has always recommended distilled water with Redline Water additive. Been faithful to that suggestion for years, and no rust evident in our Bracket SBC's.
RT - SS/X circa 1972.
Talbot Racing Family
1720 is offline   Reply With Quote
Old 06-13-2014, 05:47 PM   #3
Brett C
Liked 1,018 Times in 217 Posts
Royal Purple
Brett Candies
4192 Stock/SS
God Bless America
Old 06-15-2014, 03:39 PM   #4
Kegracing
x2 for the distilled water and Redline Water wetter.
Not saying it is any better, but I have had good luck with it. No rust issues, no radiator issues, and no water pump issues.
Kegracing is offline   Reply With Quote
Old 06-17-2014, 04:27 PM   #5
John Bender
Liked 61 Times in 12 Posts
I have used Red Line water wetter for years and have no radiator (stock one for stock eliminator) problems. I had to use Royal Purple once, the car ran hotter than any time I ran Red Line.
John Bender 1969 STK
John Bender is offline   Reply With Quote
Old 06-17-2014, 04:36 PM   #6
Ed Wright
Ed Wright's Avatar
If you ask the tech officials, they will likely tell you to run straight water, as this other stuff is harder to clean up off the track if you leak some. That is what they told me.
Ed Wright 4156 SS/JA
Old 06-17-2014, 06:45 PM   #7
VanPelt
VanPelt's Avatar
I just got emails from both Div 4 NHRA and IHRA regarding Redline Water Wetter stating It's approved in the cooling system.
VanPelt is offline   Reply With Quote
Old 06-17-2014, 08:40 PM   #8
FireSale
FireSale's Avatar
Liked 237 Times in 126 Posts
Sounds like a chemical called Photo Flow that I used when I did film photography. Breaks the surface tension and makes the rinse water sheet off the film for spot free drying. I can see that being good in a radiator. It was always all over the lab floor and I don't recall it being a clean up issue.
Dale
Dale Shearon
68 Mustang 6394
