Old 05-26-2014, 04:13 PM   #1
Bruce Noland
Liked 444 Times in 145 Posts
Default 71-72 Small Block Chev motor & assorted parts
71-72 Small Block Chev motor: 350/270
Carb to pan, includes water pump and ATI balancer - plug it in and you're ready to go.
This motor has ten passes on it, .750 under.
It has:
CP Pistons,
Total Seal rings,
Chev rods
Bushed lifter bores
Latest Bullet Cam
Comp Cam springs
Schubeck lifters
Complete Whitaker Valve job - angled milled heads
Whitaker Balancing
Nice race prepped Quadrajet
Electric water pump
AtI Balancer
New bearings when freshened
New roller timing gear set when freshened
Your choice of 71 or 72 intake manifolds or you can buy both. They are very clean and legal - been through Indy tear down.
$4,500.00
Also have for sale:
Fresh, solid shifting, Metric Transmission (forward pattern) by Leon Miranian $1,250.00
Several good metric converters: $400.00 each
Two barrel intake manifolds for 71, 72 and 73 Chev 350. They are also very clean, $250.00 each
BM Pro Ratchet Shifter: Set up for three speed forward pattern, also have reverse pattern and Powerglide plates as well. Two shift cables. This unit has a lever on it and after ten passes I had had enough. About $600.00 worth of shifter and parts. Now $350.00
Also have a 6,600 Watt Yamaha Generator for sale. New battery for electric start and remote start. Produces 120 and 220 Volts. These units are now selling for $3,000.00+ but will sell this one for $1,250.00. It is in excellent shape and runs very strong. It does have one kink - it will, on occasion, burp a couple of times on a cold start and then take off and run great.
I sold my business last fall and now moving to a smaller unit to store my trailer and car.
Thanks for reading,
Bruce
703.989.4104
shopsilvercloud@aol.com
Bruce Noland 1788 STK
Old 05-27-2014, 04:46 PM   #2
Bruce Noland
Default Re: 71-72 Small Block Chev motor & assorted parts
Bobby L,
I can't respond to your message because you have a blocker on this site. The converters flash between 5,200 - 5,400 with a 400 HP 350 - depending on the air.
Old 05-27-2014, 07:11 PM   #3
Rob Petrie E395
Liked 216 Times in 77 Posts
Where are you located? Is this a RV Generator or more like a construction generator? If possible could you send a photo of it to LMLamar70@yahoo.com.
Thanks
Old 05-28-2014, 09:17 AM   #4
Bobby Lundholm
Liked 127 Times in 49 Posts
Bruce,
That's strange I've never blocked this site. I have a 396/350 HP combo so I will probably have to have it tightened up then. How soon are you looking to get rid of it?
Bobby Lundholm 3516 G/SA
Bobby Lundholm is offline   Reply With Quote
Old 05-29-2014, 07:27 PM   #5
fred goodwin
fred goodwin's Avatar
Liked 35 Times in 11 Posts
Bruce ,you have a PM
fred goodwin is offline   Reply With Quote
