Old 05-24-2014, 01:00 PM   #1
Mike Fuller
Liked 203 Times in 80 Posts
Default G Force Chips
Has anyone had experience with this product? Sounds to good to be true.
http://www.gfchips.com/?gclid=CODC2f...FQcSMwodH0QARA
Mike Fuller 396 STK
3961 SS
Old 05-24-2014, 01:22 PM   #2
David Lee
Liked 346 Times in 126 Posts
Default Re: G Force Chips
Pure snake oil
The "chips" that you are talking about though show a complicated looking "computer chip" but, when you get it, you will see that it is nothing more than a cheap plastic box with some wires hanging out of it that you are supposed to splice into your IAT ( Idle Air Temperature ) sensor harness and the cheap resistor that is inside the cheap plastic box is meant to fool your engine control module into thinking the air is cooler than it really is
Old 07-10-2014, 10:51 AM   #3
Gil Brannan
I bought one-same as David described. Put it on my v6 Dakota. Ran a tank of gas thru it first--Hwy. Then hooked it up and ran the second tank of gas thru it. Exactly the same. even put the g-Tech pro on it later. No improvement at all...Worthless.....
Gil Brannan is offline   Reply With Quote
