Old 05-08-2014, 06:56 PM   #1
HEMIDARTDAVE
Liked 4 Times in 3 Posts
Default 426 Hemi Spark Plug Tubes
I'm having a tough time finding a set of 426 Hemi spark plug tubes. Anybody have any or know where I can get a set.
Old 05-08-2014, 07:25 PM   #2
M&M Motorsports
Default Re: 426 Hemi Spark Plug Tubes
Try Charlie Westcott or Ray Barton .
M&M Motorsports is offline   Reply With Quote
Old 05-08-2014, 10:44 PM   #3
ss3011
ss3011's Avatar
Liked 239 Times in 114 Posts
There are several sets on eBay.
ss3011 is online now   Reply With Quote
Old 05-09-2014, 12:03 AM   #4
HEMIDARTDAVE
Barton does not list any, Westcott has his own style tubes, but there was one listing for a correct set of the original type of aluminum tubes. The last time I checked Ebay, there were none, but now this seller has a few sets. Thanks for the tip!
Old 05-09-2014, 12:11 PM   #5
Todd Hoven
Guest
Posts: n/a
Barton will have what you need, call them
Old 05-09-2014, 05:58 PM   #6
Phillip marvetz
Phillip marvetz's Avatar
Bob Mazzolini should have them also. 951-787-8783
2009 V/SA Record Holder
Old 05-09-2014, 08:38 PM   #7
ss3011
ss3011's Avatar
Charlies' Spark Plug Tubes are sweet, and allow you to remove the valve cover without having to remove the spark plugs. There is an adapter that sells on different sites that create a better seal so the tubes don't re-lie on the spark plug gasket to seal oil from the spark plug tube. Those are highly recommended. Charlies' tubes need those adapter to work.
Old 05-10-2014, 09:11 AM   #8
Jeff Teuton
Liked 325 Times in 50 Posts
I think I have a set of new ones and used ones all factory. I will check Monday.
Jeff Teuton 4022 STK
Old 05-10-2014, 06:25 PM   #9
HEMIDARTDAVE
I bought a set on Ebay...the seller had 20 sets, and was down to 5 left when I got one. Thanks guys for your info. Now I can fire up the beast!
