Old 04-11-2014, 02:29 PM   #1
Eric Merryfield
Eric Merryfield's Avatar
Liked 503 Times in 131 Posts
Default Any one switch from Hoosier standard radial to lightweight?
Has anyone back to backed standard weight drag radials with the lightweight versions?
Not sure if the standard weight tire is the same tire with more rubber or not. Although the standard is listed as a C07 compound and lightweight as a C06.
Can you run more tire pressure in one over the other?
Thanks
Eric
Eric Merryfield 1883 STK
Old 04-11-2014, 03:14 PM   #2
Jim Kaekel
Liked 541 Times in 112 Posts
Default Re: Any one switch from Hoosier standard radial to lightweig
I backed-to-backed them a couple of years back and the lightweights may be .01, .02 quicker at best. I've run about 6-8 lbs. more pressure than I ran in the regulars with success. As they say, you're results may vary.
Jim Kaekel 3836 STK
Old 04-13-2014, 10:42 AM   #3
CrateCamaro
CrateCamaro's Avatar
Liked 19 Times in 7 Posts
I know they dont last as long thats for sure. Ordered a set by accident...very dissapointed. Burnout procedure is way different if you want them to last. Didnt have them long enought to see a difference....LOL.
Tony Valerio 1968 Camaro
1700 IHRA H/CM
1701 NHRA SS/?A
Old 04-13-2014, 12:05 PM   #4
boostedf22c
boostedf22c's Avatar
Eric knows all about the longevity of the lightweights.
Carey Bales
316D DD/AT
www.racetactics.net
boostedf22c is offline   Reply With Quote
Old 04-13-2014, 04:22 PM   #5
1720
1720's Avatar
Liked 2 Times in 1 Post
We switched from 18212 to 18209 in 2008, after about 80 passes on the 18212's. Just ran 2 seasons [214 passes] on the second set of 18209's, and 60's were the best & most consistent we've seen right to the end of last season...once we learned how to do a "proper" burnout! I.E. - only clean them till they start to haze, not try to set them on fire!!
RT - SS/X circa 1972.
Talbot Racing Family
1720 is offline   Reply With Quote
Old 04-14-2014, 07:38 AM   #6
rallye bob
rallye bob's Avatar
Liked 6 Times in 4 Posts
From what I was told, they are the same tire. Only difference is they make the CO6 lighter by taking material (rubber) off the side wall..... I have done back to back CO6 to CO7.. got the same 60' times the CO7's lasted about 25 passes longer before I started losing 60' times
