Old 03-03-2014, 11:02 PM   #1
5343stk
5343stk's Avatar
Default Black AN Hose
I installed new Earl's Black AN Hose when I re-built my car approximately 4 years ago. Over the years, I have noticed it is getting harder / less flexible each year. The shape I formed for my carb line is especially inflexible. I have a Product Engineering Pump and am afraid I will blow these lines apart with the pressures this pump makes. I do not want to re-plumb the car, but would hate to burn it down over a few hundred dollars of fuel line.
Your thoughts...
James & Kari Findell
(2) 1973 Plymouth Duster's 340
NHRA Stock Eliminator
5343stk is offline   Reply With Quote
Old 03-04-2014, 01:18 AM   #2
FED 387
Liked 333 Times in 180 Posts
Default Re: Black AN Hose
if it is the Kevlar with ptfe inside you're probably ok if its rubber probably time to replace it the rubber will deteriate and get soft---FED387
Old 03-04-2014, 07:15 PM   #3
Tom Goldman
Tom Goldman's Avatar
Liked 883 Times in 237 Posts
This happens with all hose , it's just more obvious with the cloth covered hose than the wire covered type .
I replace my fuel hoses every 3-4 years to avoid problems from deterioration .
Old 03-04-2014, 08:12 PM   #4
jim hensley
If you decide to change, I recently changed over from the black nylon braided hose to fragola series 6000 ptfe lined steel braided hose and use their real street fittings. I am very happy with this so far. no more fuel smell.
jim hensley is offline   Reply With Quote
Old 03-05-2014, 05:05 PM   #5
Robin Lawrence
Sponsor
Liked 716 Times in 120 Posts
After several year the hose with the rubber liner will get stiff. There are other types as mentioned that will hold up better but are much heavier and more expensive.
I have had to replace mine as well.
And I work at Holley/Earls
Robin
STK 308
SS 3088
Robin Lawrence is offline   Reply With Quote
