Old 02-27-2014, 04:53 AM   #1
87gt50
Default What oil to use in a Jerico DR4-4?
What oil are you using in the Jerico DR4 Rev4 gearbox? And how much?
Any difference between oil brands?
87gt50 is offline   Reply With Quote
Old 02-27-2014, 09:42 AM   #2
Run to Rund
Liked 54 Times in 27 Posts
Default Re: What oil to use in a Jerico DR4-4?
I have the regular DR4 and use Torco RTF. Jerico sells lube also.
Old 02-27-2014, 09:53 AM   #3
terry1
Liked 24 Times in 13 Posts
Wink Re: What oil to use in a Jerico DR4-4?
I have the DR4,not rev 4.I have been using 75-90 synthetic, never a problem.
I have used Castrol in the past.I am using Royal Purple this year, for no particular
reason.I fill till the oil can be seen in/at the fill hole.
terry1 is offline   Reply With Quote
Old 02-27-2014, 10:09 PM   #4
Jamie Greening
Redline light weight shockproof gear oil. 1 quart. Can pull cover off trans and still clinging to cover.
Jamie Greening is offline   Reply With Quote
Old 02-27-2014, 11:11 PM   #5
james schaechter
Liked 1,439 Times in 301 Posts
What he said!
James Schaechter 3163 STK
Old 02-28-2014, 02:15 AM   #6
Rory McNeil
Originally Posted by james schaechter View Post
What he said!
I also use the Redline lightshock blue oil in my Jerico DR4s, and the pink Heavyshock in the rearend.
Like Jamie said, the stuff clings like crazy, I removed the cover after the car sat all winter, and the lube was still clinging to the top and sides. Good stuff.
NHRA 6390 STK
M/S 85 Mustang
Old 02-28-2014, 01:07 PM   #7
John Nechiporchik
Liked 13 Times in 7 Posts
How much lube are you guys running in a GM 12 bolt?
John Nechiporchik is offline   Reply With Quote
Old 02-28-2014, 04:04 PM   #8
terry1
I use one liter(Canada eh) 75/90 synthetic in my 12 Bolt.
Same oil/lube as my DR4
