Old 02-23-2014, 09:48 PM   #1
rutledge
Default Turbo Action tranny parts - complete engine
2.08 planetary - light weight, aluminum hub, aluminum drum - all for a glide. Make offer
350 stocker engine, 295 hp, currently in 67 camaro, D,E,F - intake to oil pan, electric water pump available, .60 under with little work. Q-jet also for sale. $2800 for engine and components.
$3500 for everything.
PM for details, pics
rutledge is offline   Reply With Quote
Old 02-24-2014, 06:53 AM   #2
HandOverFist
HandOverFist's Avatar
Liked 33 Times in 16 Posts
Default Re: Turbo Action tranny parts - complete engine
Interested in the 350/295 - Any detailed info on components (casting #'s on heads, intake) and internals? Time slips available for this combo?
Thanks,
Rich
Rich Taylor
I/SA - 321
Old 02-26-2014, 01:09 AM   #3
rutledge
Intake casting numbers are 3905893 and cylinder head numbers are 3890462.
The car has been .60 under in current trim but the engine has gone .82 under in a good car.
Manley rods, Moroso pan, Comp Cam, roller rockers, CSI water pump, filled block, ATI damper,Moroso valve covers.
Last edited by rutledge; 02-26-2014 at 10:53 AM. Reason: Left out a number for cylinder head castings
Old 02-26-2014, 02:45 AM   #4
HandOverFist
Originally Posted by rutledge View Post
Intake casting numbers are 3905893 and cylinder head numbers are 389046.
Your intake is most likely a 3905393. No idea on that head casting number...not a number I have ever seen or heard of.
Rich Taylor
I/SA - 321
Old 02-26-2014, 12:39 PM   #5
Bobby Lundholm
Liked 128 Times in 50 Posts
It's in the NHRA guide.
295 350 .002 Flat 1945/1505 390/410 Outer w Damp .018 462,041,186,492,291
Bobby Lundholm 3516 G/SA
Bobby Lundholm is offline   Reply With Quote
Old 02-26-2014, 02:23 PM   #6
HandOverFist
Post #3 was edited...
Rich Taylor
I/SA - 321
Old 02-26-2014, 04:07 PM   #7
Mike Pearson
Mike Pearson's Avatar
Liked 1,983 Times in 597 Posts
462 are a double hump head. commonly known to some as camel humps or fuelies. used on quite a few combos in the late 60's
Mike Pearson 2485 SS
Old 05-06-2014, 07:47 PM   #8
quinnb1967
Hi I'm interested in the gear set what will you take for it if you can give me a call on my cell 905-512-9469 ask for Quinn thanks
quinnb1967 is offline   Reply With Quote
Old 05-07-2014, 09:35 AM   #9
ss wannabee
Liked 7 Times in 7 Posts
How much for tranny parts?
ss wannabee is offline   Reply With Quote
