Old 02-23-2014, 02:31 PM   #1
Default "Real" Pontiac Stocker
Tibor asked me to place this ad here on C/R for him..
Some of you guys might know the car..
Stock Automatic Combo class winner @Firebird, many Nat'l and Div. finals...Tied for #1 in 2006 National points.
This is a rust free, SoCal car...super clean inside and out.
K, L, M/SA
Can run N/SA with a Formula hood.
Two engines, two transmissions, spare parts..whole deal, now reduced to $23,000
All the good stuff, in car now... $18,000
This car will be at the Wild Horse Divisional, 2/28 to 3/02
Stop by and see us, or
Call me @602-769-0346 or Tibor (at bottom of ad)
1977 Pontiac Firebird K,L,or M/SA Stock Eliminator. Pontiac 350 engine. CP pistons, Eagle rods, Comp Cam. Boburka carb. MSD dist. Jet Hot coated Dougs Headers. Metric 200 trans with 2.91 low first gear. Turbo Action shifter. ATI converter. Mickey Thompson wheels. 4 wheel Wilwood disc brakes. Caltracs with split mono-leaf springs. 12 bolt rear end. 33 splin Moser gun drilled axles. Pro gears with girdle cover. In L/SA 12.70 index car runs 11.90s in bracket mode. You can run many different engine combos in this car. 400 Pontiac. 305,350 Chevy. 350,403 Olds. Also included with the car is a spare intake to pan 350 Pontiac Stock Eliminator engine and fresh Metric 200 trans with 2.75 low first gear.
Contact Tibor Kadar 602-769-0590 or email algoat8u@aol.com $23,000.00 or best offer.
**** Update: This car was the # 5 Qualifier @ the Div 7 race in Az.
Real easy to drive and hit the tree with.
Plenty more left in this combo too.
On a .93 under pass, last run at Wild Horse , 3/02/14
If you're serious about going racing...here you go!
ID:	22966   Click image for larger version
Name:	Picture 307sm.jpg
Old 09-16-2014, 10:46 PM   #2
Default Re: "Real" Pontiac Stocker
Car has been sold..Thank you, C/R
