Old 02-22-2014, 08:04 PM   #1
bent98
Default Weld Draglite Rims/Tires .10 bolt 8.5 Complete rear
Selling slightly used pair of Front Weld Draglite, Aluminum, Polished, 15 in. x 3.5 in., 5 x 4.50/4.75 in. Bolt Circle, 1.375 in. Backspace with 165/80/15 Tires. Tires have about 150 miles on them and rims are in excellent condition.$399
10 bolt 8.5" rebuilt rear with Eaton Posi 4.10 gears Moser 30 Spline Axles, housing cut for ford big bearings, c-clip eliminator, 5x4 3/4 1/2/20 3inch studs, new drum brakes and brake cylinders, aluminum Housing Cover, 1350 Spicer pinion Yoke.
Rear has about 700 miles on it.
$1400
Call 917 214 0775
Regards,
Greg
Call
Send SMS
Add to Skype
You'll need Skype CreditFree via Skype
bent98 is offline   Reply With Quote
