Cam-lifter break in methods....open valve spring pressure
OK.......we have done all the necessary pains to not wipe the cam out at break in time....the cam is coated and polished, the tool steel lifters are coated, the open spring pressure is 400 lbs.......is there a minimum spring pressure that requires a light spring break in and then the heavier spring or is changing springs required on any open spring pressure regardless of how low the spring pressure ???
NHRA AND IHRA STOCK ELIMINATOR 2772
