Old 02-19-2014, 09:36 PM   #1
FED 387
Liked 333 Times in 180 Posts
Default 2000 Ford F250 warnng light flickering
have 2000 Ford F250 Diesel on the way home from work the light in the lower left corner of the dash looks like a battery started flickering--- lights seem OK amp gauge is where it should be. If the engine RPM is over say 1500 the light goes out but intermittently might come back on--- at an idle up to about 1200-1500 in neutral the light will maybe stay maybe go off--- I'm thinking alternator might be going bad--- is there a voltage regulator on these things?? Any suggestions what it is??? Both batteries are less than 4 years starts OK too---- Any suggestions on where to look??? What is the alternator supposed to put out (voltage) at an idle or wherever I test it---thanx FED 387
Old 02-19-2014, 10:55 PM   #2
Rob Petrie E395
Liked 216 Times in 77 Posts
Default Re: 2000 Ford F250 warnng light flickering
Pull the alternator off it and have it tested. Most auto parts stores do it for free. My bet is its going bad.
Old 02-19-2014, 11:48 PM   #3
FED 387
thanx Rob that's what I was thinking too-- will check it out tomorrow--FED 387
