Old 02-19-2014, 01:12 PM   #1
Mike Crutchfield
Liked 4 Times in 2 Posts
Default Garage Parts sale
Complete top end CFE 10 degree Chev wedge heads with new valves, valves springs, retainers, locks, Jesel rockers, push rods, cast aluminum valve covers and heads studs. Very good stuff
Matching CFE manifold 2x4 for 4500 with adapters for 4150 for 8.200 deck
Matching CNC -CFE manifold 2x4 for 4150 for 8.200 deck
Jesel keyed lifter 8 offset 8- centered
Chev-615x 15 degree heads new in the box
SBC-321ci complete engine fresh off the dyno 12degree Slawco, All Jesel front distributor, jesel belt, jesel rockers, jesel lifters, ATI balancer, CSR water pump, Moroso Pan, Hogan manifold with 2x4 and 1x4 tops, MSD crank trigger, King light weight crank and much more.
Mallory Hyfire Pro ignition box
2.940 light weight crank
221147 and 22148 Manley polished triple valve springs with retainers
Comp cam NEW roller lifters 8-offset 8-centered
Moroso chrome valve covers
Hooker header collectors 2-2in tube x 4 opening 4-2 1/8 tube x 3 ½ opening 2-2 1/8 tube x 4 opening
Burns stainless merge collectors 1 7/8 x2.5 x 3 ½ bell
TCI- 7inch converter 13-30 .050tc
2-142 tooth Chevy Aluminum Reactor flywheels 1-new 1-used and starter noise for flywheel
Complete Power glide in parts- With shield, pump, 203 planetary, Aluminum drum
loaded, Hardened input shaft, Aluminum pan , Pro-Brake- Ready to put together
Very rare Jeep 904 transmission core with Chev bell housing bolt pattern
Many sets- cam lock seat belts great shape needs new date.
Motivated seller -Send offers or questions to
mikec2610@bellsouth.net
Mike Crutchfield is offline   Reply With Quote
