Old 02-11-2014, 06:54 PM   #1
hotrods1795
Liked 2 Times in 2 Posts
Default Backspacing
Does anyone know the backspacing on a 1963 Dodge Polara - stock eliminator car for a 10 inch wheel. I have an 8 in wheel now. The car has cal-tracs. Any help would be appreciated.
hotrods1795 is offline   Reply With Quote
Old 02-12-2014, 10:49 AM   #2
John Dinkel
Liked 263 Times in 68 Posts
Default Re: Backspacing
I have 5 in on my 64 Plymouth
John Dinkel 3295 STK
John Dinkel is offline   Reply With Quote
Old 02-12-2014, 12:58 PM   #3
Run to Rund
Liked 54 Times in 27 Posts
If your current 8" wheel puts the tire where you want it, add 1" to its backspacing.
Old 02-12-2014, 01:02 PM   #4
Run to Rund
One other thing, the section width of the tire will probably increase a little, about .3" in and .3" out at the sidewalls, with the wider wheel.
Old 02-12-2014, 01:22 PM   #5
John Dinkel
You might have to bend the inner lip of the wheel opening too.
Old 02-12-2014, 06:13 PM   #6
hotrods1795
Thanks for all the info - really appreciate it.
Old 02-13-2014, 03:47 PM   #7
Alex Denysenko
Alex Denysenko's Avatar
Liked 4 Times in 3 Posts
we sold the force 5 bogarts to Dave Young for his 63 and Gene Mosbeck for his 64 and I'M pretty sure John Dinkle as well they were all 15X 10 and had a 5 inch BS.
Alex Denysenko NHRA 3038 SS, 3305 STK - IHRA 6 SS, 330A STK
Moneymaker Racing LaPorte Indiana 219-861-1214
www.moneymakerracing.net
Alex Denysenko is offline   Reply With Quote
Old 02-14-2014, 06:25 AM   #8
GTX JOHN
Liked 2,487 Times in 698 Posts
I had 10 inch with 4 1/2 BS 64 Ply. With 65 rear end with no Key axles.
Wider/ Later Rear End will require more BS. What year rear end are you
using and what width and I can tell you more exactly?
Most everybody who ran these cars replaced the weak and difficult to remove
Keyed axles with a later model rear. Many years had the same spring perch
width ( about 44 inches ) but differing widths of housings affecting the back spacing
choice.
You should have some leeway because we used to run 10.5 width in SS without any
mods except wheel lip.
John Irving
741 Stock
741 Super Stock
Old 02-14-2014, 06:24 PM   #9
hotrods1795
I bought the car out of Mass. and I don't really know what year rear is in the car, but I do have an 8" rim on the car now w/4 1/2' bs on the car now.
