Old 02-07-2014, 09:20 PM   #1
Lonnie Cox
Default Valve clearance after the run
350 sbc good valvetrain.
Clearance on engine stand
intake 045 exhaust 065
should turn 7k through the lights
After run will they hit? when you just let off
Lonnie Cox is offline   Reply With Quote
Old 02-07-2014, 10:09 PM   #2
ron mattson
Liked 68 Times in 31 Posts
Default Re: Valve clearance after the run
I can't say it will not work but I would shoot
For .020 more clearance minimum. If you
Can't get any more I would be very careful
In the burnout box and watch shift points
Carefully as well as spring pressures.
Ron Mattson 5015 STK
ron mattson is offline   Reply With Quote
