Old 02-06-2014, 04:06 PM   #1
Joe Toller
Liked 9 Times in 9 Posts
Default Variable Venturi carbs?
Has anyone raced with a VV carb? According to my specs I have to use a 2700 Motorcraft VV carb on my 77 302. Or, because it reads off a oxygen sensor and, being a feedback style carb is of sorts a computer-controlled unit, can I just use a traditional 2150?
Joe Toller
Lewistown, MT
Old 02-07-2014, 09:40 AM   #2
Mike Taylor 3601
Mike Taylor 3601's Avatar
Liked 308 Times in 103 Posts
Default Re: Variable Venturi carbs?
I remember VV carb being vac controlled,I remember changing plenty of the diaphrams that controlled the variable venturi,sliding back and forth in top of carb.don't remember any electronic wiring going to those carbs,only wires I remember is choke and idle solenoid
Mike Taylor 3601
Old 02-07-2014, 04:28 PM   #3
Joe Toller
I might have been thining a later VV...Ill raid one from the junkyard this weekend and take it apart and see whats up...
Joe Toller
Lewistown, MT
Old 02-07-2014, 07:52 PM   #4
Tom keedle
Tom keedle's Avatar
Liked 8 Times in 7 Posts
some were 'puter controlled and some were not
all were a pos as far as I'm concerned...
there USED to be a holley conversion for them years ago, did one on a comp controlled Lincoln once
never raced one though
Old 02-08-2014, 10:50 AM   #5
Mike Taylor 3601
They blew diaphrams like crazy then slides in top would.nt move ran like choke was on.
77 I would guess is non electronic version
Mike Taylor 3601
Old 02-08-2014, 05:37 PM   #6
Dave Noll
Dave Noll's Avatar
Liked 240 Times in 112 Posts
One of the shops I used to work @, the owner told me that when they were working right they were a good gas mileage carb.
Dave Noll, EF/S ,?/SA 6526
Old 02-08-2014, 09:05 PM   #7
Joe , Get an early one and open the top flap and then tell me why you wouldn't want to use it.
BTW, ANY type of linkage for single or multiple carbs is acceptable with NHRA.
What I'm saying is I wouldn't be dependent on a leak prone diaphragm if that's the case.
Old 02-08-2014, 09:10 PM   #8
Joe Toller
Gotcha. I will get to the yard as soon as I see at least 20 degrees out lol!
Joe Toller
Lewistown, MT
