Old 02-06-2014, 01:06 PM   #1
Steve Polack
Liked 4 Times in 1 Post
Default 92 Camaro SS/CM or GT/? or SMA
1992 SS/CM Camaro roller or parts - Car SOLD. 342 Inch Motor still available.
I raced this car for many years in GT/FA & GA with much success. I switched to modified in 2004. The car is currently set up to run SS/CM but can be easily switched back to a GT car by installing the steel hood, which comes with the car. In 2004 I did a complete rotisserie restoration on the car and stripped the many layers of paint off inside and out. I replaced everything and I mean everything. I have not raced the car since 2009 after freshening up everything. This car set and held the 2007 SS/CM national record. It is a top qualifier and winner. You will not find a nicer launching super stock. I will sell this car as a roller with the following for $20,000 OBO.
* Lamb brakes and struts,
* Mark Williams center section and gun drilled ultra light axles,
* Mark Williams aluminun drive shaft,
* AFCO double adjustable rear shocks with assortment of springs,
* Anti roll bar,
* Magnaflow fuel pump,
* MSD programable digital 7
* 16 volt V Performance AGM batteries
* Autometer
* Weld Aluma Star front and rear.
* New Hoosier radials
* Two fiberglass hoods with scoops and original steel hood for running GT.
* Headers for both short deck and standard deck and also a set of Stahl step headers for running GT.
Visit Racing Junk for photos add # 182124351
http://www.racingjunk.com/Stock-Supe...GT-or-SMA.html
206-697-0515
rainierfriesians@hotmail.com
Steve Polack is offline   Reply With Quote
