Old 02-04-2014, 10:36 AM   #1
philbilly
philbilly's Avatar
Default transfer tanks/towing
is there any nice ones for a dually. I would like to see what some of you guys have in your trucks. a tool box with the tank in the bottom is what I am leaning towards.
It needs to look nice . I would want it hooked direct to my fuel system .
2007 duramax
pros and cons??
how many extra gallon 50?? 100?
philbilly is offline   Reply With Quote
Old 02-04-2014, 02:09 PM   #2
ab5098
Default Re: transfer tanks/towing
I use a transfer flow tank in mine came with the truck works great not sure what they cost mine is 75 gal. 02 ford f-350
https://www.transferflow.com/fuel-tanks/in-bed
ab5098 is offline   Reply With Quote
Old 02-04-2014, 02:34 PM   #3
Rick Blake
Rick Blake's Avatar
Had a guy in Naples, FL build me a custom 90 gallon tank out of .090 aluminum for the GMC Dually for $275.00 complete with baffles.....best move I ever made and had it designed so the roll-top would slide right over it
Rick Blake 2395 SG, SC, SP
Rick Blake is offline   Reply With Quote
Old 02-04-2014, 02:39 PM   #4
KennyAnderson
Liked 357 Times in 119 Posts
Phil wish we talked before the weekend. A bud of mine and I were making some and I got one in my dually. Tall and skinny rt at the front of the bed. Push the toolbox back a tad and put er in. 45 extra gallons and it gravity feeds into the stock tank. Its perfect for me. I can go roughly 800 miles towing my LQ w/o a fuel stop. Havent made any in a while but could probably gear up to make a few. Problem is I was using ATP and buying virgin aluminum it was hard to keep the cost down.
KennyAnderson is offline   Reply With Quote
Old 02-04-2014, 02:42 PM   #5
KennyAnderson
$275!! Holy S--t! Musta had leftover materials or something cause the material bill could easily be $275.
Old 02-04-2014, 02:50 PM   #6
Rick Blake
Rick Blake's Avatar
Could be Kenny.......friend of a friend....at his home shop.....but it was very nice work and also back in 2007. Some of the prebuilt ones I looked at were pretty much the same price back then....but couldn't find one that would fit under the roll-back...
Old 02-04-2014, 04:12 PM   #7
FED 387
Liked 333 Times in 180 Posts
perhaps try a heavy duty truck salvage yard--- they dismantle Semis/buses/vans/straight trucks and you can pick them up in my area a used tank for about a buck a gallon!!!
Old 02-04-2014, 04:29 PM   #8
DIAPERMAN
Liked 21 Times in 6 Posts
Talking Re: transfer tanks/towing
Had a PIT Pal on my F550 80 Gal NICE unit
DIAPERMAN is offline   Reply With Quote
Old 02-04-2014, 05:07 PM   #9
Run to Rund
Liked 54 Times in 27 Posts
I also use Transfer Flow, and highly recommend them. Back in the 90s I used a W---gard tank. It cracked and rusted so I went through a lot of fuel filters before giving up on it.
Old 02-05-2014, 05:09 PM   #10
Myron Piatek
Liked 138 Times in 51 Posts
Post Re: transfer tanks/towing
Darn, too bad I didn't know because I coulda showed you the 60 gal. w/tool box I have in my dually. It's under my topper, but I switched the sliding window around so I can open it at the front and fill the tank through it. But the window does leak some when it rains. I've also seen some set-ups where the filler cap is built into the side of the topper. It's made by RDS which are sold by Northern Tools. I got mine at a local truck supply store.
It is gravity feed with a shut-off valve. I believe I read somewhere that you are not suppose to keep it open while on the road per DOT regs. Hope someone can clarify. But I open it at the track and it refills the main tank there.
It's great to be able to skip through the higher fuel price states!
LOCOMOTION Racing
