I am putting a car together to run in SS/AM. I have a couple questions I hope can be answered here. The carb rules are a little vague. There is a short list of approved carbs that are all 4150 type carbs and then basically any Holley.
Also I need clarification on the OE NHRA accepted cylinder heads. NHRA allows certain Edelbrock heads in Stock and Super Stock. I have heads with the correct casting number but do not have the NHRA logo engraved on the ends. Thanks in advance. |
Liked 29 Times in 5 Posts
SS/AM is modified so basically you can run any carb, 2 4bbls if you want. Heads have to have GM Part # if a GM car or Ford # if Ford etc. Gm splayed valve or Gm 15 Degree are the norm for heads.
SS/AM 2917 |
Liked 805 Times in 245 Posts
Be careful about running a single 4bbl in modified, there was some issues brought up in tech a few years ago where people were running super mod cars in modified to avoid heads up runs, the consensus was that you can't cross over. I know it shouldn't matter but it was the way the rules were interpreted by tech.
If the heads are on the list as approved heads in Stock/Super Stock but are made by Edelbrock would they be legal?
Liked 237 Times in 126 Posts
I haven't wandered much out of the Ford section of the Classification Guides, but the legal replacement Edelbrock, AFR and (I think) Canfield heads are listed by number. At Summit Edelbrock has an NHRA Legal badge on the right heads.
Dale
Cylinder heads must have an OEM part number, not aftermarket.
In the case of the approved Edelbrock heads, they are for Stock and Super Stock classes. Also, although I do not have the rule book handy, I believe SS/AM allows you to use a canted valve cylinder head in lieu of a wedge cylinder head. |
Liked 880 Times in 311 Posts
OEM part numbers, but I don't think the DRCE 4.90 or 5.0 bore space heads are legal for SS/AM. You have to stay away from certain Pro Stock heads because of the bore space. It has to have stock bore space, like 4.840 for BB Chevies.
There is, or was, a fast SS/AM car that has been eleminated because of the bore space rule. Be careful!!!
Adger Smith (Former SS) Last edited by Adger Smith; 02-05-2014 at 03:05 AM. Reason: sp |
Liked 9 Times in 8 Posts
hemi? I see it listed in AS but not AM
#9 | |
My question is if the Edelbrock heads which are on the list as approved castings for certain combinations in stock or super stock can be used in SS Modified. They are not OE but they are approved for Super Stock. For example the 1968 428 Pontiac combination that is allowed to use Edelbrock heads. If I took this combination added a dual four barrel intake and carbs and ran @ 7 #/CID would this combination be legal?
