Old 02-02-2014, 06:51 PM   #1
richie 2
Liked 205 Times in 93 Posts
Default dually gear change
88 chev 1 ton, dana dually rear. gonna take the gear change plunge...3'55? any horror stories? tks.
richie 2 is online now   Reply With Quote
Old 02-04-2014, 08:56 AM   #2
Kirk Morgan
Liked 81 Times in 45 Posts
Default Re: dually gear change
Depending what your current gear ratio is you may have to change the carrier. Other wise on drama. Depending on which engine you have and tire size i like 3:73s better.
Kirk
Kirk Morgan is offline   Reply With Quote
Old 02-05-2014, 12:12 PM   #3
richie 2
tks kirk. I believe they are presently 4;56....16'' wheel/tire. 383ci hyd. roller block stroker, drt. torquer heads w/TBI. th.400 trans....not sure if there is a milage/towing converter available?
Old 02-05-2014, 09:38 PM   #4
Liked 1,874 Times in 422 Posts
ATI has a converter for it.
If you're pulling much, a 383 won't get it done with 3.55 gears. It'll do well to pull a heavy load with 3.73 gears, most small blocks are better off with 4.10 gears, even with a 3.75" stroke.
Fooling with small block engines in bigger heavy trucks, it seems most get better mileage and live longer with 4.10 gears.
There are a lot of 16" tires, some taller, some shorter. It makes a difference.
