Old 02-01-2014, 05:17 PM   #1
Pistol Pete
Pistol Pete's Avatar
Liked 795 Times in 210 Posts
Default Tow Vehicle
Is a Chevy Or GMC 3500 Ext. Passenger Van OK to tow with.
Are their any Cons to using one of these vehicles ???
It's RWD, Has a 6.0 motor, 10,000 lbs. towing capacity.
Trans Cooler, ect.
I'm guessing it should be just as good as a Suburban right ??
Thanks
"Pistol" Pete Dutko
Old 02-02-2014, 12:01 PM   #2
james schaechter
Liked 1,438 Times in 301 Posts
Default Re: Tow Vehicle
We towed with a friend's 1 ton van once and it had the brakes and suspension to be safe. It was not nearly as easy to drive as a burban! No way would I choose a van if I could have a suburban. Short trips, maybe no biggie, but on a real long trip, the van was a chore to drive and ride in compared to a suburban. Maybe it is the wheelbase?
James Schaechter 3163 STK
Old 02-02-2014, 02:36 PM   #3
jmcarter
jmcarter's Avatar
Liked 3,202 Times in 977 Posts
Pete, I imagine some of what James is describing could be contributed to how stiff they spring the 3500 Vans to accommodate the high cargo loading they are designed for. Combined with the Highway Rib tires you see on them...no doubt they need the 10-12 ply tires but imagine Michelins are other quality radials would improve their road manners. I would; however, be concerned with visibility out of them, making changing lanes and backing a trailer without a spotter a bit more challenging.
Jim Carter
2340 Super Stock
2340 SST/2340 Stock
Old 02-02-2014, 03:30 PM   #4
Pistol Pete
No, I'm talking about a Van with windows, like the 12 passenger kind, not a cargo type van. The Passenger kind should have nice tires on them.
Any thoughts & reply's are Greatly Appreciated.
Why i'm asking, my YukonXL 2500 has 207,000 miles, wondering if it's worth putting
a New Crate Motor in it or sell it to buy the Van.
"Pistol" Pete Dutko
Old 02-02-2014, 08:04 PM   #5
tj310
1 ton GM van with the longer wheelbase , worked great . It's all about the rear overhang ---Trevor
Old 02-03-2014, 09:43 AM   #6
pistol paul
try them all you will find one you like
pistol paul is offline   Reply With Quote
Old 02-14-2014, 09:06 PM   #7
Pistol Pete
I'm guessing a 3500 is a 1 ton chassis on a Van ????
"Pistol" Pete Dutko
Old 02-15-2014, 10:27 AM   #8
tj310
!990 GM introduced an extended van we bought one new . Unlike the Dodge extended van where thy added 2' behind the rear wheels GM extended the wheelbase. On further recollection ours was rated as a 3/4 ton 2500. The first thing I did was remove 2 leaves from each side so it sat level. Never changed anything else in the suspension. I liked it better than the Suburban we had used but missed the 454. There is the theory that you need a full frame to tow but I was happy . Really wanted the interior room without stepping up to a motor home. This was a bare bones van 350 air am radio , it was 1/2 the price of a new suburban at the time. I wouldn't hesitate to go with the newer 3500 6.0 van , like I said it's all about the rear overhang ---Trevor
Old 02-15-2014, 12:03 PM   #9
Pistol Pete
Thanks for enlightening me on these vans. Yes, i like them too, little cheaper than a motorhome.
Just wondering if they were good for towing is all.
It sounds like they are as long as you get the 155" wheelbase one.
"Pistol" Pete Dutko
Old 02-15-2014, 02:10 PM   #10
Dave Ribeiro
Liked 56 Times in 27 Posts
Wink Re: Tow Vehicle
Pete,
Check on what a GM crate motor cost & have it put in ... Is the Sub. in good shape, if it is you can get another 5-8 years out of it, for not much more than 3-4 K !!! Plus you know what you have in the Sub. they make great tow trucks ... ( I have had 14 of them ) Good Luck....
Dave Ribeiro 1033 STK
