Old 01-14-2014, 09:14 AM   #1
mat H/SA
mat H/SA's Avatar
Liked 14 Times in 8 Posts
Default front end 69 nova
Hi
what type bushing ball joint etc is the best,
im looking to refresh my stuff
thanks for you help
mat H/SA is offline   Reply With Quote
Old 01-14-2014, 10:24 PM   #2
Marty Rinehart Jr
Marty Rinehart Jr's Avatar
Location: Rineharts Performance Race Cars, Thomasville,PA
Liked 333 Times in 75 Posts
Default Re: front end 69 nova
I don't know if it's the best but it's what we use.
Global west bushings and extended ball joints. They sell it in kit form
Marty Rinehart Jr
1125 SS STK SG SC SST
Marty Rinehart Jr is offline   Reply With Quote
Old 01-15-2014, 01:18 AM   #3
Todd Bailey
Liked 33 Times in 17 Posts
Matt,
Check out Howe Racing Enterprises. That have extended ball joints that go up to .9 long.
Todd Bailey is offline   Reply With Quote
Old 01-15-2014, 06:31 AM   #4
Alan Nyhus
Liked 799 Times in 236 Posts
Mat, I went with Energy Suspension urethane control arm bushings, Moog #K5250 offset control arm shafts and standard Moog replacement ball joints.
Afco and ProForged make low friction extended upper ball joints. QA-1 has standard length low friction ball joints that can be serviced. -Al
"That'll never work....."
Old 01-15-2014, 08:34 AM   #5
J&S Racing
Liked 319 Times in 82 Posts
Afco steel bushings and there low friction ball joints, the Afco tops can be ordered .5 longer.
Old 01-15-2014, 09:41 AM   #6
FLEMING
Liked 55 Times in 26 Posts
I just did what J&S posted and it made my car totally different! It was an easy install, car has a ton of front end travel now and drives like a dream
FLEMING is offline   Reply With Quote
Old 01-15-2014, 06:29 PM   #7
mat H/SA
mat H/SA's Avatar
Thanks for the help guys!
Old 01-16-2014, 04:43 PM   #8
joe cool
Liked 5 Times in 3 Posts
Are the replacement bushings roller bearing or something like that ? When you say steel bushings does this mean its steel to steel ,no bushing material ? The longer Ball joints are for reducing camber change? thanks
joe cool is offline   Reply With Quote
Old 01-16-2014, 05:47 PM   #9
J&S Racing
The global west bushings are aluminum and derlin I believe and the Afco's are solid steel with grease fittings.
Old 01-18-2014, 09:42 AM   #10
mcashman
Liked 6 Times in 3 Posts
What is the point of the longer ball joints?
mcashman is offline   Reply With Quote
