Old 12-30-2013, 02:55 PM   #1
Rick Carlson
Default Add ATF or repair/replace trans?
Our 2007 Explorer Sport Trac V8, 6 speed automatic, with 115k, slips in overdrive and when making a right turn after a stop. In years past this usually indicated time to add trans fluid. I looked for the dipstick and couldn't find one . Manual says there is none as this tranny doesn't leak and to take to dealer for service. Help! Is there a way to check and add fluid, or does this really need to go to the dealer for repair? That just sounds expensive.
Thanks,
Rick Carlson
"We never knew quite what he did...until he quit doing it!"
Rick Carlson is offline   Reply With Quote
Old 12-30-2013, 03:55 PM   #2
slingshot
Default Re: Add ATF or repair/replace trans?
[ame="http://www.youtube.com/watch?v=rUP-nOsoJMA"]Checking and Adding ATF to Ford Trans Without Dipstick - YouTube[/ame]
slingshot is offline   Reply With Quote
Old 12-30-2013, 04:30 PM   #3
Rick Carlson
Thanks. Explains it well.
