Old 12-29-2013, 05:32 PM   #1
SAL PIACENTINI
Default 350 Pont SS engine and Trans
77 350 Pont 170/250. Ashley Q-jet,Wilson spacer,Holley int.6X heads,stainless valves,K-Motion, & Comp titanium retainers.400 block sleeved to 3.935 w/Ross pistons &Total Seal .043 rings.Early steel rods,polished,bushed to 927 pins,cyro'd, & ARP bolts.Fresh Armasteel crank.3runs on rings & bearings.Canton box style pan.MSD crank trigger & billet dist.ATI damper.Lunati 708/645 @ 281/281,Comp,lifters,pushrods, & rockers.ATI 8" MRT conv.T-400 w/275 1st,Griner brake,alum direct,ATI center support,lightened parts, & deep alum pan.Ran this combo for years in SS/MA.11.85 index @ 3680lbs.Qualifies 6 to 85 under depending on bracket to kill mode.Best run 10.86 @ 122.70 in -300 ft air.Cam design is 35 yrs old & several better available today.Drop in 9" tire stocker for SS & it will pick up as I always run 14X32's.In car running. $8000.00 for all. 443-553-5941-Sal
SAL PIACENTINI is offline   Reply With Quote
